Brief Description: Rear window and aileron trim installation
Today I installed the fuselage rear window. Following this I assembled the aileron trim bracket, crank and actuator assembly and drilled the aileron trim actuator to the cabin floor rib.
Fuselage rear window installed
Aileron trim bracket, crank and actuator assembled
Aileron trim actuator drilled to the cabin floor rib
